JTAG Chain Configuration Pane (View Menu) (Signal Tap Logic Analyzer)
JTAG Status:
Displays status messages for the Signal Tap Logic Analyzer JTAG Chain Configuration (such as JTAG ready).
Hardware:
Allows you to select the communications cable, and displays the name of the currently selected communications cable and the port to which it is connected.
Setup:
Opens the Hardware Setup dialog box, which allows you to add and remove hardware items from the Hardware list, add and remove JTAG servers from the JTAG Servers list, configure your local JTAG server, and specify a hardware setup for device programming and/or configuration.
Device:
Displays the device you use. The name of the device is in the following format:
<number on circuit
board>: <JTAG ID code>: <device name>.
For example, in the device name @1: 0x082000DD: EP20K200C:
- @1 indicates that it is the first device on the circuit board,
- 0x082000DD is the JTAG ID code for the device, and
- EP20K200C is the device name.
Scan Chain:
Scans for device(s) on the circuit board that are connected to your system. The detected device(s) appear in the Device list.
Bridge Index:
Allows you to select one SLD JTAG bridge from the current revision, by selecting the corresponding bridge index. To associate bridge index values correspont to which revision, go to the JTAG Bridge Action Report.SOF Manager Pane:
Displays controls for managing SRAM Object Files.
- Toggle SOF Manager— Displays or hides the SOF Manager pane.
- Program Device button— Allows you to use the SRAM Object File specified in the File box to program the device that you selected in the Device list.
- Attach SOF button— Attaches the SRAM Object File displayed in the File box to the Signal Tap File. You can attach multiple SRAM Object Files to a single Signal Tap File. Attached SRAM Object Files allow you to reprogram a device with a SRAM Object File that is compatible with particular instances in the Signal Tap Logic Analyzer.
- File— Allows you to specify the SRAM Object File that contains the data to program the device, or that you want to attach to the Signal Tap File.
- Attached SOF Files— Lists the SRAM Object File(s) attached to the Signal Tap File and displays which instance of the attached SRAM Object File is compatible with the Signal Tap File.
- Shortcut Menu Commands— Right-clicking an SRAM Object File in the SOF Manager pane allows access to several commands.
